Help! How Do You Operate an Atlas Scraper or Fresno?
Toyfarmer
09-30-2001 22:52:04
third party image
I need a little help on operating this Fresno? How does it operate with a rope? How do you correctly connect the rope? Any help would be appreciated. Thanks, Toyfarmer
Vern
10-01-2001 22:24:26
 Re: Help! How Do You Operate an Atlas Scraper or Fresno? in reply to Toyfarmer, 09-30-2001 22:52:04
The rope is to trip it to dump the load. When you are pulling it the front edge should be cutting into the ground so as to load the bucket. I think you have to back up to set the bucket into the travel position. When you get to where you want the dirt, pull the rope and the bucket will rotate, dumping the load and resetting for the next load.
bob
10-02-2001 18:03:03
 Re: Re: Help! How Do You Operate an Atlas Scraper or Fresno? in reply to Vern, 10-01-2001 22:24:26
thats the way it operates but mine i can trip to go to road mode. really can move a lot of dirt with it good luck
