Jon & Jerry have pretty good advise. I personally wouldn't mind a trailer (pull-type) plow, I don't like the ridgidness of a 3-point (and actually use a 2-point with movable rear wheel on the bigger tractors now...). Just personal preference I guess. I also prefer older good equipment, I think the new stuff you buy at the local Fleet & Farm is too light to hold up/ work well. I would suspect the plw could use longer plow shares. They go about $10 a pop at the local Fleet & Farm. If you wish to replace, take an old one off, take it along, & match up the holes. Many times 14, 16, & even 18" shares will match up. You want longer, especially for plowing up sod. Dad went as far as welding on 2-3" of an old share to make them longer for plowing alfalfa fields, as those roots don't like to cut off.... Does the plow pull straight behind, or is it sliding out to the un-plowed side? As stated, some have an adjustment for this, the trailing wheel has some control. Another big cause of this is worn out landsides, the long vertical part that slides along the furrows. Sometimes they get so worn out you don't realize how big & long they should be! On some plows the back one is (or used to be! :) extra long to help hold the plow in line. In addition, it sounds like you are plowing the most difficult conditions - old sod when it is very dry. This is just plain hard. As others said, if this is a one-time deal, do the best you can, disk an extra time or two, and it will work out ok. It will also plow easier next year if that is what you wish to do. Plowing doesn't need to be perfect if you don't want it to be. :) I am very, very surprised you can get a 50 hp tractor to plow through with a 3-16 plow. That is a difficult task in the soil & conditions you describe. To plow alfalfa with a 3-16, dad used to have to tie an Oliver 88 & at least the IHC 'H' together to get enough traction & power. --->Paul
