Hydralic hookup
Pete N.C.Tex
03-05-1999 00:51:55
I have a tandem disc set up with a cylinder to "pressure raise" and "unpressure lower" (one hose) for a Farmall tractor. Can I use this same setup behind a case 1175 using only one remote plug-in or do I need to add the other hose to the cylinder?.
Dennis H.
03-05-1999 02:07:08
 Re: hydralic hookup in reply to Pete N.C.Tex, 03-05-1999 00:51:55
No problem, you can use it single line as long as the vent is in the cylinder. Just plug in the one and it'll work just like with the Farmall.
pete
03-06-1999 07:36:25
 Re: Re: hydralic hookup in reply to Dennis H., 03-05-1999 02:07:08
thanks Dennis.....
