Hydraulics for JD D
Bill in Ontario
10-09-2001 09:45:33
Does anyone know if the late model styled JD "D" was ever available with hydraulics or could be retrofitted with JD parts? I have seen one D that had a pump installed between the engine case and magneto drive but the tank/resevoir looked homemade and was mounted on the righthand foot plate beside the fender. Thanks.
Green Envy
10-10-2001 15:53:52
 Re: Hydraulics for JD D in reply to Bill in Ontario, 10-09-2001 09:45:33
I have a picture in one of my books that shows a D with hydralics and a bench type seat. My GM magazine also talks about a high compression gasline attachment for the D. I wouldn't mind having a D with all of these features.
Tim(nj)
10-09-2001 11:17:40
I believe the 1949-53 D was available with Powr-Trol from the factory. Probably added when the R came out. Makes sense, as the A, B and G had it by then.
Richard
10-09-2001 20:26:33
 Re: Re: Hydraulics for JD D in reply to Tim(nj), 10-09-2001 11:17:40
According to Two Cylinder, Jack Cherry, the D never left the factory with installed hydraulics. He points out that some were fitted at dealerships.
