Dearborn 19-65 rear mount manure loader
Tim(nj)
10-10-2001 19:40:57
Found one. I want to put it on my NAA. Before I buy it, I'd like to know how this thing mounts. I've figured out where to hook the link arms, and I know that the top bracket pins to the extra rings by the toplink on the tractor. But there's this plate with hydraulic cylinders on it, that looks like it bolts under the pto housing of the tractor. I can't figure out what these cylinders are supposed to do, and where I would hook them up on the Jubilee. Anybody have an idea? I suspect they are a lift assist, but can't quite picture it in my head how to put it together.
Leroy
10-13-2001 08:06:15
 Re: Dearborn 19-65 rear mount manure loader in reply to Tim(nj), 10-10-2001 19:40:57
That mounts on the bolt holes for the swinging drawbar, some had the mounting built in with the cylinders, others used the swinging drawbar bracket, the top end of the cylinders mount to the top of the lift arms, use the standard cross drawbar to mount to the lower end of the lift arms
