What kind of corn, field or sweet? You will not make any money on small plots of soybeans & field corn, but that might not be the object. :) If it is field corn, do you want to pick it on the ear & store it (needs a crib that air can flow through) or combine it (you'll need a way to dry it, or sell it _right_ away at a discount). These things will make a difference on what you use to harvest your crops. Otherwise, a harrow (drag) to level ground, a planter (for corn & maybe soybeans, sunflowers, more?) and a grain drill with grass seeder attachment (for hay, maybe soybeans, more?).
You need a way to control weeds, cultivator if you get the planter, sprayer if you get the drill. Harvesting will either be a corn picker and a combine, or a combine that has both a cutter table & a corn head. And a wagon. Sickle mower or more to cut the hay. Do you notice you picked crops that are very different, and you need 2 of everything? You may wish to start out with a couple items that use the same machinery and advance up in later years. --->Paul
