3pth A Frame considerations for old Allis disk plow
ShepFL
10-15-2001 21:36:41
Having never built a 3pth attachment I am requesting some Tractor gods experience.
For the Allis? Disk plow posted a few days ago I plan to a) remove front hitch assy, b) bolt or weld a HD Cat. 1 drawbar in it's place for the Oliver's lower lift arms c) build an "A" frame from 1/4" flat stock for the top link. d) Also plan to add a chain (adj) connecting top of A frame to some point on the plow rear of the A frame (like on a bush hog).
Questions -
1) Any special metal or construction techniques to consider for the A frame itself?
2) Any issues with the adjustable chain?
3) Cat. 1 drawbar heavy enough for lift arms?
Dave C
10-16-2001 12:26:05
 Re: 3pth A Frame considerations for old Allis disk plow in reply to ShepFL, 10-15-2001 21:36:41
I don't think 1/4" bar for the A-frame is heavy enough. A plow pulling in the ground or hitting a rock is going to put a lot of force on all the framework. I'd go at least with 1/2". Also, I wouldn't think you'd want to have the amount of "float" that a chain will provide at the back end of the plow. Make the framework solid. You will adjust front to back tilt by changing the length of your top link.
ShepFL
10-17-2001 08:27:25
 Re: Re: 3pth A Frame considerations for old Allis disk plow in reply to Dave C, 10-16-2001 12:26:05
Dave - Thanks for the comments. I agree with the 1/2" stock. I had not thought about the "float" with the chain. Very good point. I will post pics as I progress. May very well drop you a line requesting additonal information. Thanks again.
