Ford model 250 Knotter problem
Mayfarm
10-17-2001 17:22:58
I just had my knotter repaired after breaking the twine holder on one side. After reinstalling the knotter the repaired side is operating flawlessly. The other side will do everything except for tie the knot it holds the twine and cuts the twine but does not tie it. Any suggestions. Thanks for the help.
Jerry D in NC
10-18-2001 20:46:00
 Re: Ford model 250 Knotter problem in reply to Mayfarm, 10-17-2001 17:22:58
Do you get any part of the knot. Does it wrap around the billhook. Not Tying can be a bunch of things so you need to describe the thing better.
mayfarm
10-19-2001 08:58:31
 Re: Re: Ford model 250 Knotter problem in reply to Jerry D in NC, 10-18-2001 20:46:00
It looks like it starts to wrap around the bill hook and gets a partial twist. It did try and make a knot a couple of times but you could pull it apart real easy.
Jerry D in NC
10-19-2001 13:21:31
 Re: Re: Re: Ford model 250 Knotter problem in reply to mayfarm, 10-19-2001 08:58:31
A couple of things to start with. Billhook tongue tension and Twine Finger adjustment. Do you have a manual?
Mayfarm
10-20-2001 06:29:22
 Re: Re: Re: Re: Ford model 250 Knotter problem in reply to Jerry D in NC, 10-19-2001 13:21:31
I do not have a manual and my local dealer did not either , do you know where I might check for one? Thanks again.
Jerry D in NC
10-20-2001 08:13:56
 Re: Re: Re: Re: Re: Re: Ford model 250 Knotter problem in reply to Jerry D in NC, 10-20-2001 08:11:28
OOps the paper parts manual is $16 STILL worth it
