Howse bush hog
ole tex
10-20-2001 16:28:31
just bought a howse bush hog 6' mower and when i engage the pto and rev up the engine it turns fine and smooth but when i put the tractor in gear and take off, the mower blades bang up against the mower housing making a loud noise.What do you guys think the problem could be? thanks
JoeKssdfa
10-23-2001 20:16:38
 Re: Howse bush hog in reply to ole tex, 10-20-2001 16:28:31
Hey, don't know what the trouble is, but if you find out post it here. My Howse does the same thing
Bob8n
10-23-2001 19:12:52
I would check all hardware, and make sure everything is tight. Blade bolts may need 300ft/lbs or more(check manual). Is there gear oil in gear box? This I would check daily, as leaks from below won't get detected. Most gearboxes are designed for 545rpm. don't exceed that.
Bob8n
Burrhead
10-20-2001 20:44:18
The stump jumper may be loose. The Howse 600 and 600S are bad about being put together p-poor, or at least these here are.
They may have left the gearbox mounting bolts loose.
