52 Ford 8-N: Is it possible to run Snow Blower W/O Sherman
Sean K.
03-07-1999 15:44:56
I have a 1952 8-N with a factory transmission. I want to run a snow blower off the pto and would like to know if there is any way to do this. Is there an adaptor or any manufacturer that has come up with a solution to this problem?
DaBrow
03-07-1999 16:29:47
 Re: 52 Ford 8-N: Is it possible to run Snow Blower W/O Sherman in reply to Sean K., 03-07-1999 15:44:56
The Sherman is of no help as it is in front of the orginal tranny. It WILL slow you down in reverse( if an under Sherman)but will also slow down your PTO speed.The old catch 22. The 8n also has a single stage clutch.When the clutch is depressed the PTO stops also.Bummer!! You can't clear the blower,I know I've tried this.As for the adapter,one is available to go from 1 1/8" 8n output to the newer 1 3/8" blower shaft. A HUPP tranny which is behind the tractor tranny will slow you down in reverse,but not slow the PTO speed.BUT there is still the single stage clutch!!! DaBrow
francois
01-17-2000 05:01:05
 Re: Re: 52 Ford 8-N: Is it possible to run Snow Blower W/O Sherman in reply to DaBrow, 03-07-1999 16:29:47
Cher ami il est facilement possible d'installer une souffleuse sur un 8-N,de viens d'ailleur dans acheter un 8_N 1952 que j'ai overall au complet.
en 1958 dans ma ville Rimouski Québec.toutes la neige dans les rues etait déblaiyer avec des 8-N
IL AVAIT INSTALLÉ LA SOUFFLEUSE EN AVANT DU TRACTEUR AVEC UN DRIVING SHAFT! la vitesse du reculon a 1750 RPM.est de :5.31 MPH
(1)first gear a 1750 RPM.est de :3.23 MPH see you Francois
