Dearborn disk
duane
11-05-2001 15:25:36
I'm about to replace the blades on my old 3pt Dearborn disk. Several are broken off. I looked and priced the blades at TSC. The plain ones are around $8.00 and slotted around $9.00...I have seen pictures of disks with slotted in front and plain in rear and some the other way around. Mine has plain on front and back now and thinking about using the slotted blades.
Does the slotted blades work better on not and should I put them on front or back?????
Thanks Guys
Frank Burgess
07-03-2002 09:47:31
 Re: Dearborn disk in reply to duane, 11-05-2001 15:25:36
You said you priced blades from TCS, would you mind telling who that is and where their located. I'm in northern Colorado, and am looking for a supplier.
Jerry D in NC
11-05-2001 17:00:39
Put the notched on the fron and the smooth on the back. Think of it as cut and level
