Saws, belt pulleys, what the heck?
68 Mag
11-08-2001 15:40:37
Ok. I have some questions about saws. There are some in my area, that are basically a 4 legged table made of angle iron with a big circular blade on one side, connected via a shaft to a belt pulley on the other. What are these used for? I dont see how it could be used to cut firewood, but maybe I'm missing something. I intend to log about 5 acres for firewood, would one of these saws help me that much?
Scott
11-15-2001 10:12:59
 Re: Saws, belt pulleys, what the heck? in reply to 68 Mag, 11-08-2001 15:40:37
We still use our tractor driven cordwood saw pretty often. We run it off the Case Sc, JD B, or the Farmall Super A. These work well for cutting 4 footers into stove length. Actually we cut all to 54" in the woods and to 18 with the cordwood saw. We only use it on smaller diameter wood though, stuff that doesn't have to be split. Try lifting a 54" log 12" in diameter onto a table, you won't want to do it too often. If you are giving it your full attention, it is no more dangerous than anything else. It works well, but mostly we do it to keep the iron running over the winter.
Indiana Jones
11-09-2001 15:47:55
Here in Indiana we called them buzz saws. My grandfather used one powered off his John Deere most of his life. Used it alone and never lost any body parts. He never owned a chainsaw.
My dad used one powered off his Allis Chalmers for maybe 10 years until I grew up and left home. Then he converted the furnace to gas. Good timing, right?
But anyway, these things were designed for a situation where you cut 4"-8" logs out in the woods to maybe 8'-10' lengths. You hauled them up to the woodshed in a trailer and proceeded to cut them to firewood length on the buzz saw. Our blade was probably 32" in diameter, but it was pretty much impossible to cut anything bigger than 8" in diameter due to binding. The teeth had to be sharpened and set every Saturday morning before we started cutting.
Every once in awhile I get nostalgic and think maybe I should get one to run off my Farmall. Then better wisdom prevales and I go fire up my chainsaw.
Take it from someone who has been there. A chainsaw is many times more efficient than a buzz saw, and while dangerous in itself, it is far less dangerous than a huge spinning blade.
IaGuy
11-09-2001 10:30:30
It takes two people, log lengths they can lift and you are only crosscutting to stove length. Table or stand kind need staking to ground and the tractor has to back into belt tension and set the brakes, often something moves and throws the belt.that is why many saws are fastened to front of tractor. It is a pretty ringing sound while cutting and hearing the tractor snort. Chainsaws are better deal, believe me. Good luck!
paul
11-08-2001 21:28:20
They cut a lot of firewood. But they cut a lot of limbs - arms, legs, fingers - too.
Might want to just buy a second chainsaw - those are dangerous too of course. Back in the old days, chain saws weighed 50-100 lbs and started once in a while.... The tractor saw looked pretty good in comparison. Nowadays chainsaws are lighter & dependable.
--->Paul
buck
11-08-2001 16:45:37
been many a moon since I helped dad using one of those- usually cut the laps/logs into lengths that one or two peope can handle and lay them on the swinging table and cut to firewood lengths. they were pretty good when you could get the slabwood from sawmill that didn't have to be cut before using this saw. For your project I would recommend three chainsaws one large saw for felling one smaller saw for trimming and a large bowsaw for cutting the logs into firewood lengths.hey--good luck
