4 ft ford brush cutter
Hilbert
11-22-2001 17:45:27
I was given a ford brush cutter, 4ft. It works great and has a real heavy duty gear box. Problem, there's a large hole rusted through part of the deck, (about twelve inches in diameter.) The rest of it seems fine. Can I justy weld a piece of plate over the hole? What is the best fix?
Bob
11-23-2001 08:38:43
 Re: 4 ft ford brush cutter in reply to Hilbert, 11-22-2001 17:45:27
If it was me I'd cut the rust hole out far enough so your into good metal and then weld in a replacement panel and grind down the welds and paint it so it don't rust, if you just put a patch over the top brush will hang up in the hole and cause more problems, you could patch it on the underside and and get by as well.
