1495 Swather
Bob
11-23-2001 18:47:24
I'm trying to change out the the top roll on my swather and really need some help. 1st I'm not sure how to remove the drive in key from the drive sprocket and 2nd after you get the roll loose how do you get it out of the unit? Do you have to let the lower roll down or what are the required steps? Anything will help. Thanks in advance.
RickB.
11-25-2001 14:38:25
 Re: 1495 Swather in reply to Bob, 11-23-2001 18:47:24
Most, if not all NH haybine headers require the bottom roll to be removed to allow the top roll to come out. The easiest way to remove a gib key is to drive the sprocket off the key and towards the bearing, if clearance allows. Once the sprocket moves, the key can be pried out.
