Help me identify old loader please!
Zonie
11-25-2001 18:59:18
I'm tyring to identify a trip bucket loader that I'm looking at for possable purchase.
The loader may have been painted red at one time but it's really hard to tell for sure. It has a chain drive hydraulic pump inside a rectangular hydraulic tank. The chain drive runs off the pto.
The system uses 90 wt gear oil as per the only tag I could find on anything. The trip bucket is very heavy duty, much heavy dutier than most trip buckets I've seen. It has 1"x1" solid steel ribs about every 6" or so around the out side curve of the bucket.
The loader arms are straight (will fit a narrow front end only)and are 2 pieces of 2"x3" angle iron welded together. They appear to mount to the rear end housing in some manner.
The hydraulic cylinders are one way only and very heavy duty. 3" with about 2" piston shaft.
The cylinders mount to plates that look as tho they shold mount to the side of the clutch housing, I think, with a 2" solid steel shaft that goes under the belly. This loader came off of a 1940's(?) cockshutt tractor that came from North Dakota.
I'm sorry about the long discription, I took my digital camera with and it just refused to take any pictures! It worked fine after I got home!
The farmer wanted $150 for it and it looks complete except for the mounts that go to the rear end.
RayP(MI)
11-27-2001 07:46:03
 Re: Help me identify old loader please! in reply to Zonie, 11-25-2001 18:59:18
Would sure like to see some pictures, could you try again? Check out the loaders on this site:
Zonie
11-27-2001 17:34:53
 Re: Re: Help me identify old loader please! in reply to RayP(MI), 11-27-2001 07:46:03
From the pictures on the "carrot patch" link it does look as tho it mounts the same as the Horn loader and the basic configuration is similar. however the loader seems heavier built, especially the bucket. The underbelly mount looks just about the same and I don't believe it has double extension cylinders.
Thanks
wayne woods
11-27-2001 04:40:22
For that price you can affort to have some fabrication work done to make it fit your tractor. I've been dreaming of getting one to fit my 504 Farmall, but the sticker shock gives me a severe case of the heebie jeebies!
Try your camera again, and also take lots of measurements relating to how it would fit your tractor. Your favorite machine/weld shop should be able to give you some rough idea of the retrofit cost.
As far as replacement parts go, I wouldn't be too concerned. As long as the cylinders are structurally sound and the piston rods are not rusted/pitted, aboaut all that could be wrong would be the seals. As far as hyd pumps go, get yourself a catalog from "Surplus Center". They have loads of hyd stuff. If you can't find a matching replacement, you sure can find an alternate pump which could be substituted.
Surplus Center
1015 West "O" Street
P.O. Box 82209
Lincoln, NE 68501-2209
Toll free order # is 800-488-3407
Fax 877-474-5198
You could probably get them to send you a catalog by calling their order number above. (Better get busy, looks like you've got work to do getting that loader outfitted to your favorite tractor!)
WW
