The tractor tips site gives the 1510 as having 20 HP PTO and 16 HP drawbar. This is not too far different from an 8N. I have an 8N and it pulls a 2 bottom 14 inch moldboard plow. If your soil is not hard with a lot of rocks and clay, this should work. I pull a 7 foot tandem disk but 6 might be more appropriate. I have an old 2 row covington planter and cultivator I use but it I were out looking and not going to do an awful lot of acreage, I might have gone the one row route. Your tractor would have handled a 2 row though without trouble. Used prices vary greatly but you should be able to find all for 2-300 price range each around these parts. A real of thunb on the plow is 15 HP per each 16 bottom plow I am told. On the disk, look for one with sealed bearings, ie no grease fittings if you can. If you go the other route, make sure you own a grease gun and use it with 3-4 squirts before each use.
