Brush Hog for F-20?
Tony Pitts
11-26-2001 16:26:58
Hi all,
I finally have moved from the city to 5 acres and will be needing to brush hog most of it. I have a '37 F-20 on steel and was hoping for some advice on picking out a brush hog.
Thanks!
Leroy
11-30-2001 17:58:23
 Re: Brush Hog for F-20? in reply to Tony Pitts, 11-26-2001 16:26:58
Your big problem is the PTO as the farmal did not have a standard PTO shaft, needed an adapter, unless you have it will be hard to find. Get that first then look for the mower.
Taylor Lambert
11-29-2001 06:04:00
Hi Tony, Im assuming that your tractor has no hydraulic lift, youd need a drag type brush hog. these are fairly common around here for years i had an uncle that farmed out of all his new machines he had an F20 on steel to bush hog old black berry and thorne bushes that littered his farm. it saved him loads of money on tire patches. I have a few of these drag type bush hogs if your interested best regaurds Taylor Lambert
Tony Pitts
11-29-2001 08:59:12
 Re: Re: Brush Hog for F-20? in reply to Taylor Lambert, 11-29-2001 06:04:00
I'm interested. Are you anywhere near Michigan?
What might the asking price be?
Thanks for your help!
taylor Lambert
12-03-2001 17:24:39
 Re: Re: Re: Brush Hog for F-20? in reply to Tony Pitts, 11-29-2001 08:59:12
Hi Toney i live in North mississippi Im asking 200 for the 6 foot pull type
