Ihc cultivator and corn planter!!
derek
11-27-2001 18:21:22
i know a guy with a corn planter and cultivator in great shape. there both a two row deal, and are in good shape. he wants 99 dollars, and there for a super c. my question is would they fit on my h tractor and how would i be able to work them with a cylinder? is it possible? thanks derek.
Mark A
12-03-2001 09:40:51
 Re: ihc cultivator and corn planter!! in reply to derek , 11-27-2001 18:21:22
I'm pretty sure it will not fit on the "H". The implements bolt to the "lift framework", of the Super C tractor, which is attached to the tractor at the front, and the seedbox is mounted to the side of the Super C, and is driven off the disc brakes with a chain. The lift is hydraulic, and lifts the "framework", which lifts the planter (or cultivator). The cultivators bolt up to the "framework" as the planters did, so the croprow spacings are the same. For the planter to work correctly on a Super C, you will need the disc brake chain sprocket, lift rods, chain, in additional to the furrow opener and seed box, with "plates". Also, the flexible tube connection between the seed box and the furrow opener. These can be hard to find, and are easily damaged, or rusted. Good luck.
derek
11-28-2001 19:05:53
it does not run on the fast hitch. the man said that it bolts on the side of the tractor and runs off of some chin type hydrolic system. not real familar with the supers, i was going too buy a super c but got a m and a 450 diesel instead. hope this helps, derek
any one else wanna try!
11-29-2001 17:57:38
 Re: Re: ihc cultivator and corn planter!! in reply to derek, 11-28-2001 19:05:53
can anyone else help me with the extra information i have provided. thanks derek
sammy the RED
11-28-2001 06:09:06
Not if they are mounted implements.
Buy them then get a Super C.
Wayne Woods
11-28-2001 04:40:35
Derek, You need to give the group a little more info. Are the implements 3 point hitch?, fast hitch?, pull type? or what? What type hitch system does your tractor have? My limited knowleges has learned that there are two sizes of IH Fast Hitch. Implements with the smaller type can be easily adapted to tractors with the larger system. Not so easy to go the other way.
Give a little more info, and some of these guys with tons of experience can easily answer your Q's.
WW
