Ford 501 vs John Deere #9
Boo
12-01-2001 10:31:51
Hey fellas! Need your input on which mower I should persue. Have heard good remarks on both mowers, but which would hook-up easiest to a MF 35 tractor. These mowers seem reasonably priced just wandering what mower would be the better choice. Need a sickle bar for the ditch and a few other places that I can't get with the brush hog. It will save me time and I won't have to use the weed-eater as much. Thank for your help.
Jim.UT
12-05-2001 12:55:42
 Re: Ford 501 vs John Deere #9 in reply to Boo, 12-01-2001 10:31:51
I have a JD #9 that I use with a Ford 800 series. First couple of times hooking it up took a long time. Finally got smarter. Now I can do it in about 10 minutes. I've been able to get parts so far, but I haven't needed anything major.
Tom A
12-03-2001 06:37:19
I'm not familiar with the JD, but I have a Ford 501 that I use on my 48 8N.
Though I haven't needed very many, parts have not been a problem--New Holland has had every one I needed and the prices have been reasonable. Even loaned my their copy of the owner's manual until my reprint came in.
Honestly, hookup was bewildering for me even on the 8N (one of the tractors it was designed for), but I was not at all familiar with sicklebars at the time. Until I got the manual, I could not make it work very well. Now I suspect you can make the 501 work on about any similar-size and equipped tractor, though you may have to tinker a bit to get the adjustments right.
good luck,
Tom
LazyHorse
12-01-2001 17:44:31
I think you'll find JD still maintains parts for their older mowers. Ford / New Holland has discontinued a lot of their older parts.
