IH 412 FH plow question
smirkey
12-03-2001 09:02:13
We have this 4 bottom 14inch spring trip plow with super chief bottoms that needs some work. Its an early "semi-mounted", it is a fast hitch plow with a cylinder assisted caster tail wheel. The frogs are worn and the plow points get bent down due to the lack of support from the worn out frogs. This winter i am going to look for used parts and wonder if most IH plows use the same frogs? are the frogs the same from the 16 inch plows as well?
