IH disk plow
norbert kanzler
12-04-2001 17:39:19
I have a chance to buy an old IH 3 bottom disk plow. It was used on an M I want to use it on a Ford 5000. Does anyone have a manual for this disk plow? Or can you tell me how it was hooked to the tractor?
bbmcc@bellsouth.net
12-05-2001 18:08:54
 Re: IH disk plow in reply to norbert kanzler, 12-04-2001 17:39:19
If it is a HM-150, you removed the drawbar and a rockshaft that lifted the plow bolted there. A mounting frame bolted under the belly of the tractor to both sides of the cast piece that enclosed the lift-all pump. The plow pulled from that. If it is a 3 wheel plow it just fastened to the swinging drawbar.
bbmcc@bellsouth.net
12-05-2001 18:08:41
norbert kanzler
12-07-2001 07:27:11
 Re: Re: IH disk plow in reply to bbmcc@bellsouth.net, 12-05-2001 18:08:41
I have not purchased it yet. The price is only $50 but I want to use it with a Ford 5000. I thought maybe I could use a 3 point hitch drawbar instead of the M drawbar but i did not know exactly how it is hooked up. I do not know the model number. There is the IHC emblem cast into one of the coulters. It has one rubber tire in back and one steel wheel on the left front. I am willing to pay the price asked but need information on how to hook it to my Ford. Do you have an operator's manual? Or pictures on one hooked to an M?
Bob
12-07-2001 12:17:32
 Re: Re: Re: IH disk plow in reply to norbert kanzler, 12-07-2001 07:27:11
Was never available With 3 point hitch. It is very heavy, but was one of very few disk plows that would plow in very hard ground.
norbert kanzler
12-07-2001 16:08:58
 Re: Re: Re: Re: IH disk plow in reply to Bob, 12-07-2001 12:17:32
No problem with it not being 3 pt hitch. I just need to figure out how to hook it up to the Ford 5000. Do you have any pictures or manuals of it attached to the M?
