Breather for Hydraulic Cylinder
JDHUMP
12-13-2001 21:05:56
Where can I purchase a breather for a two-way cylinder that will only be hooked up to a one-way hydraulic system????? Thanks JDHUMP
JDHUMP
12-14-2001 14:46:27
 Re: Breather for Hydraulic Cylinder in reply to JDHUMP, 12-13-2001 21:05:56
Thank you kindly for you help guys. JDHUMP
Doc
12-13-2001 21:38:51
Northern tools has them mail order, along with others. If you are buying cylinders locally try there. Doc.
Dick Davis
12-14-2001 03:13:32
 Re: Re: Breather for Hydraulic Cylinder in reply to Doc, 12-13-2001 21:38:51
TSC, Fleet & Farm, Country General or whoever sells hydraulic cylinders/components in your area. Many times a 1/16 or 3/32" hole drilled in a pipe fitting plug or even the plastic dust cover that comes with a new cylinder will work jsut fine and the price is right. Dick
