How to transport a drag disk?
Big Buck
12-20-2001 18:17:38
Does anyone have any info or old pictures showing what type of tool was originally used to transport drag type disks? Any info is appreciated. I would like to fabricate one this winter but I need some sort of "go by" for an idea.
Guy
08-13-2002 18:36:42
 Re: How to transport a drag disk? in reply to Big Buck, 12-20-2001 18:17:38
I use a 3-point lifting boom. With the drag disk attached to the drawbar, I lift the drag disk with chain attached to the 3-point boom. Works fine and the disk never touches the roadway. Good luck, the lifting boom is great for all kinds of transport/lifting chores.
MarkB
12-22-2001 06:00:54
We used to use a couple of different trailers for hauling equipment that you could couldn't pull down the road. This was eastern Colorado, where big one-way disks and wide drills are common.
The first one, which my dad built, was a big contraption that was a framework that you backed over the implement. It's pretty difficult to describe, but the thing was at least eight feet wide and about 30 feet long. It had two wheels on each side, near the middle. The framework was mounted on the wheels so that it would pivot on the wheels, and the frame was about eight feet high. Running down the middle of the frame was long shaft that had cables attached to it every few feet. Short lengths of chain were attached to the cables. The shaft was driven by a small gas engine via a worm gear. You would back over the implement so that the direction of the trailer was 90 degrees to the direction of the implement, hook up the chains and hoist the implement up. After safety chaining everything so it couldn't swing, you could take a 20 foot wide implement down the road and stay legal. We used it to haul all kinds of oddball stuff, even the occaisional broke down pickup that couldn't be towed. One nice thing was that you didn't need to have a tractor on hand to load or unload the implement.
Another trailer we used was the commercially built Donahue implement trailer. It is basically a flatbed trailer, but you can detach the bed from the axles and have just the bed laying flat on the ground. You can see a picture of one in the link below. It looks like all of the Donahue models would be too big for your needs, but you could easily fabricate a small one.
JD830
12-21-2001 18:19:42
I have a homemade implement carrier that I use to transport my drag disk and springtooth. It has an axle on the back and about 8 feet between the axle and tongue. The frame has about 3 1/2ft clearance underneath it. It has two rods with cranks on the end that run along each side of the frame, attached to each rod is two pieces of cable with hooks on the end. To transport the disk you have to move it over the disk by hand and then hook it to your tractor or truck. Then you just hook the hooks on each gang disks and then turn the cranks and lift it up and then your ready to go. Hope this
Roger
12-21-2001 10:53:05
Some companies built small wheels on a steel bar that wedged under the gang and then you pryed over which raised the disk onto the wheels, then they had a chain that hooked around the gang back to itself.
rickm
12-21-2001 10:37:05
The only time I remember hauling a drag disk was many moons ago. We set the disk straight, chained a 8' 4x4 across the front gangs and one across the back gangs (on top) and then strung a log chain from the front 4x4 to the back one and picked it up with the manure loader on the 'M' Farmall, from the side and loaded it on a hay wagon. It was an 8' double disk (Dunham I think).
I think that may have been the only time we did it
because it wasn't long after that we bought a 9' wheel disk.
Bob Kerr
12-21-2001 08:07:57
I have heard IH had a deal you could pull it up onto and go down the road with it, but have never seen one. I guess not many people had the need to get one or didn't want to spend the $$. I just turn the blades straight and go with it.
david
12-21-2001 07:46:14
We always pull ours on the shoulder of the highway for close moves (less than 1/2 mile). Have 2 farms about 8 miles apart and keep one at each place. I've been getting pieces of them at auctions in a "pile" for 50-$100. Usually can make a good one for $200-$300. That way just leave one at each farm. Wouldn't trade them for tobacco or vegetables.
Ron
12-21-2001 06:53:48
I grew up in small grain country of North Dakota and Dad owned a 10 ft IH tandem with no transport mechanism. It was ALWAYS pulled along the edge of gravel roads going between fields (there were no paved roads in the area!). The angle of the gangs was straightened (a short distance backing would do the straightening) for transport and we traveled slowly. No damage ever occurred to the disk blades. Depending on the weight of the disk it may or may not do damage to pavement. Try it for a short distance and if no damage, no other transport is necessary. Was there was ever a commercially made transport for small disks?
revredneck
12-21-2001 06:35:21
My Dad always used drag type disks. We would pull them on the road for short distances, but only when absolutley necessary. Otherwise, he put the boom on the tractor (MF135) and hoisted the disk onto a flatbed wagon for transport. They aren't that heavy, and it allows you to take your disk there and back again without much trouble. Good luck and God bless.
Lyle Oakes
12-20-2001 21:08:41
If you are talking about the old type disk that was mainly pulled by horses. You just sdjusted the disk straight and then they wouldn't cut in hardly at all. The more angle you put on the disk the deeper it would cut. I don't believe I would transport one on a road with pavement because it would probally mark it up. Hope this helps
paul
12-20-2001 20:03:50
How far?
Dad would use 4 home-sawn elm planks leaning on a hayrack, pull it up with a cable & tractor.
--->Paul
Time for cutting torch
12-21-2001 05:35:15
 Re: Re: How to transport a drag disk? in reply to paul, 12-20-2001 20:03:50
My dad had one, pulled behind 1976 cub, pulled on highway for aprox. 200 yrds. twice a year too plow other garden spot, no damage done to disc or highway. I have seen wheels welded to top side of disc so disc can be flipped over and hauled. Be Safe & Merry Christmas.
bob
12-21-2001 13:21:24
 Re: Re: Re: How to transport a drag disk? in reply to Time for cutting torch, 12-21-2001 05:35:15
befor we had loader we made a stoneboat and pulled disc on it and went down pavement had a fourty 4 miles from home on pavement tried to run partialy on shoulder worked good might have to replace skids once in a while
