Champion Oat Roller
ksmith
02-04-2002 17:54:09
I've aquired an old champion oat roller... looks like it is driven by a 3 horse motor (Separate). It drives by a large pulley which drives one of the crusher drums. The other drum drives a feed mechanism through a belt and pulley on the opposite side as the motor drive. Right now, when The motor drives the unit, only the one drum turns. Should the drums be close enough together that they both turn or does this start happening after I start feeding in the grain as the grain going between the rollers would drive the slave and in turn drive the feed mechanism. Any help on this would be appreciated as the cattle are almost out of rolled stuff and I would rather not have to buy rolled stuff when I have 3 tons of whole grain.
another doug
02-07-2002 09:45:28
 Re: Champion Oat Roller in reply to ksmith, 02-04-2002 17:54:09
although we don't have one of those, we are in the seed business, sounds similar to our machinery...try it like it is set first , then tighten it up some if results are not what you want,it's not going to take the oats real fast is it? thoses oats are going to be pretty flat so the clearance won't be much, the flow is going to probably be crucial,as it should be steady does it have a metering hopper? let me know how you're getting along with it
