Cub belly blade info
Jerry C
09-17-1998 05:30:45
I have a Cub belly blade which looks factory made. I need the replacement edge which does the scrapping. It is about 4 ft. long. anyone know where I might get a new or used replacement? Thanks in advance.
OB O'Brien
09-20-1998 05:33:42
 Re: Cub belly blade info in reply to Jerry C, 09-17-1998 05:30:45
: I have a Cub belly blade which looks factory made. I need the replacement edge which does the scrapping. It is about 4 ft. long. anyone know where I might get a new or used replacement? Thanks in advance.
Most blades use similar cutting edges. Find a paving company near you
and ask them for a used grader blade. They are about 10 to 12 ft long.
The ends get worn out from running along curbs but the middle portion
is usually still good. Take a cutting torch and trim it to the length
you need and bolt it to your old blade.
