Can you ID this old rake?
Bill in Orono,
02-16-2002 20:50:44
I have a old hay rake in the back. The rake is driven by the two 36-42 inch steel implement wheels. It has (it rotten now) a wooden toungue to pull it. There isn't a seat, or a place for one so I'm thinkng it is tractor drawn. It has a rear steel wheel 12-16" and the only manufacturer indication is a big "C" surrounding a, what looks like anyhow, superimposed I on an H. The "I" is not dotted.
Exposed gear drive from wheel axle to rake mechanism.
Case I-H? Was this partnership in existence that long ago???
The only traces of paint are green. And I had to look hard for the paint!
I'll get the model number tomorrow.
oliver farmer
03-03-2002 14:52:25
 Re: Can you ID this old rake? in reply to Bill in Orono, MN, 02-16-2002 20:50:44
what you have is a ihc rake. they did use a open gear drive. the one you have sounds like it didn't come with a seat.
oliver farmer
03-03-2002 14:52:09
Jerry S
02-18-2002 12:25:55
Chances are the seat to ride it bolted to the tongue and if it is rotten, you wouldn't be able to see where the bolt holes were.
sammy the RED
02-16-2002 21:11:29
IHC is International Harvester Corp. [Not Case]
sammy the RED
02-16-2002 21:14:08
 Re: Re: Can you ID this old rake? in reply to sammy the RED, 02-16-2002 21:11:29
International Harvester Company [Not Corp.] Sorry.
