3pt hitch pin alignment tool
Chris Jones
02-23-2002 19:49:41
I've seen a long rod that is inserted throught the hole in the lower lift arm and fits over the taper on the end of the implements pull pin and allows you to pry impliments into alignment and push the lift arm down the tool and onto the pin. Trouble is now that I want one I can't figure out where I saw it. Can anyone help?
Tom-Pa
02-24-2002 06:01:59
 Re: 3pt hitch pin alignment tool in reply to Chris Jones, 02-23-2002 19:49:41
CT use to have it with a pin with a ball on the end of it..When they merged with Quality, they had to send that stuff back that was still in stock. Now that they are both out of business, I would try some of the others..
Good luck
Tom-Pa
