Box scraper replacement teeth
Dave
02-26-2002 05:02:38
I bought a used box scraper years ago, that the past owner used until the chisle teeth were gone, and the shanks were worn short. I bought a set of weld on teeth and installed them, but they have now worn down. The shanks were worn enough that even with the new tips on, and the shanks dropped to the lowest position, I had to run the scraper at a very high angle for the teeth to dig. Has anyone found a source for reasonable priced replacement shanks?
Halsey Green
02-26-2002 06:26:49
 Re: Box scraper replacement teeth in reply to Dave, 02-26-2002 05:02:38
Try www.agri-supply.com, they have them in their catalogue. You may also try your local implement dealer, they may be able to get them for you. I have seen Bush Hog dealers with ones for their box blades. Hope this halps.
