Homemade Harrow?
Randy
03-10-2002 09:51:13
I have recently cleared and stumped about a half of an arce in my back yard. I want to level the ground and bring in some topsoil and then seed the ground to extend my lawn. I own a AC IB that I intend to tow some type of homemade harrow or drag to accomplish this. Any ideas on how to make something simple? I have access to a small welder and have about 300lbs of steel plate (elevator counter weights) to start.
Dave
03-11-2002 04:56:14
 Re: Homemade Harrow? in reply to Randy, 03-10-2002 09:51:13
I bolted 6 RR ties together and ran 10" lag bolts partly into the bottom side. Flip it over to bust up horse apples in the pasture.
Dave
Dave
03-11-2002 04:54:35
Dave
todd
03-10-2002 17:18:42
I made one using oid tires bolted together in a line then bolted to a piece of old pipe. Then use aq piece of chain from each end to the drawbar. It works good to bust up cow terds in my pasture where i feed all winter and bust up clods after discing.
kraig WY
03-10-2002 11:52:13
I had a bounch of old railroad spikes and some heavy mesh screen. I put washers on the spikes and drove them thru the screen, put washers on the underside of the spikes and tack welled the washers to the spikes. Works pretty good, put enough weight on the draw to suit you.
