Hydraulic question
Steve 450
03-10-2002 13:35:38
A friend and I were talking the other day and he brought up a good question. He has a John Deere which uses motor oil for hydraulics, and I have a Farmall that uses hytran hydraulic fluid. Will it damage either tractor (seals etc) If we pull the same implement? He is affraid that the oil left in the lines and cylinder will mix the oils together and damage the seals in his J.D. Anyone have any advice/answers? Thanks in advance.
Fudd
03-10-2002 16:15:48
 Re: Hydraulic question in reply to Steve 450, 03-10-2002 13:35:38
I would go with TP's advice and each use a different cylinder. I wouldn't mix the fluid.
TP from Central PA
03-10-2002 15:21:25
Well, I have always played it safe, and just bought "Red" tractors and have "Hy-Tran" filled cylinders to go with them ;-) I know a couple of guys over here in Nisbet have bought their own cylinders just to keep on their tractors for this problem. As I said, I only own one brand of tractor so I can't really help, but you may just buy a cylinder for your tractor and your Dad can have the other.
Steve 450
03-10-2002 17:05:06
 Re: Re: Hydraulic question in reply to TP from Central PA, 03-10-2002 15:21:25
Thanks for the advice. I guess we'll have to get another cylinder. Didn't have this problem till he put a power-troll on his B !!! Hear that Jeff, ya should have bought Red!!!
Jeff PA
03-12-2002 10:39:39
 Re: Re: Re: Hydraulic question in reply to Steve 450, 03-10-2002 17:05:06
I grew up a little farther away from the river than you guys. Mind wasn't clouded up from all those mosquitoes :). Oh yeah and remember you started it!
