Cultivator- Farmall A
Rick
03-11-2002 06:54:23
Hi guys, I have nearly a complete cultivator outfit that is in need of some restoration- found all the pieces in a field- had been unprotected for several years. Nearly all of the nuts, bolts and teeth are frozen with rust. Is is a good idea to immerse all of these pieces in a large container of kerosene to try to free everything up? Any good suggestions would be appreciated. Thanks in advance.
Manitoba
03-12-2002 08:23:20
 Re: cultivator- Farmall A in reply to Rick, 03-11-2002 06:54:23
The best rust buster I have ever used is a GM product. Part # 992955. Penetrating fluid. try it..you will throw away your WD40.
Bring back my implements
03-11-2002 17:18:08
If you are the one who picked up my implements, bring them back.
Now see what you done?
03-12-2002 06:28:40
 Re: Re: cultivator- Farmall A in reply to Bring back my implements, 03-11-2002 17:18:08
You already made him mad.
I told you not to talk about it in here.
Had us running all over last night trying to hide stuff.
The dog is even tired.
Marty Hundley
03-12-2002 05:22:58
If you can't post a name or email with your post, don't bother to post at all. To accuse somebody of taking something, and not having the guts to give a name, that's bull*#@~! Rick needs help, and you want trouble. You need to stay off if this is what you're gonna use this forum for! This pisses me off!
No implements
03-12-2002 16:47:22
 Re: Re: Re: cultivator- Farmall A in reply to Marty Hundley, 03-12-2002 05:22:58
Best to be pissed off than pissed on.
He's not the one-
03-11-2002 18:27:28
USDA told me that you took the check and didn't build the shed like you promised. So they sent me to get the stuff. T.S.
Pete
03-11-2002 15:36:19
I'd try a torch if you have access to one. It's the fastest easiest way to loosen the bolts/nuts.
