Farmall Cub Sickle mower
doug vose
03-13-2002 16:40:54
i have a belly mount sickle mower for my Farmall Cub, and the pitman mount on the flywheel broke off. is this replaceable, or can i weld it on, or am i screwed.
thank you
doug
chuck
03-14-2002 13:44:39
 Re: Farmall Cub Sickle mower in reply to doug vose, 03-13-2002 16:40:54
you can get this part from the dealer. however you will probably be better off to try to find one that can be bought for parts. I paid $25 for one that had what I needed and I still have more parts; ie: an extra sickle. good luck
chuck
03-14-2002 13:42:05
T.J._N.J.
03-13-2002 17:37:24
The part you are describing is called the wrist pin I believe it screws or presses into the flywheel and it has a seperate part number in my mower owners manual.If you can't get a new one at the dealer I am sure a machine shop would make one up for you. The part number is 451 390 R1 for the wrist pin. hope this helps T.J.
