Belt Length
Farmall B to Letz Burr Mill
Red Raider
03-15-2002 12:19:49
I sure would like to drag out the burr mill to be operated at a few tractor and engine shows this spring. Can you folks give me a proper length of flat belting to run the Letz? It is a medium size burr mill, able to move about with a 9N, but not small enough to be picked up by two persons.
Dave
03-18-2002 10:46:52
 Re: Belt Length - Farmall B to Letz Burr Mill in reply to Red Raider, 03-15-2002 12:19:49
Length doesn't matter much plobrobly around 20 feet width , match the narrow pulley or a little less.
probrobly is spelled p r o b r o b l y
fingers don't work right sometimes
Frank
03-18-2002 16:53:05
 Re: Re: Belt Length - Farmall B to Letz Burr Mill in reply to Dave, 03-18-2002 10:46:52
For the record, it's spelled "probably". Don't worry though. We knew what you meant.
Catch ya' later
Frank
Dave
03-18-2002 10:45:11
Dave
03-18-2002 10:44:41
Length doesn't matter much plobrobly around 25 feet width , match the narrow pulley or a little less.
