2 bottom pull plow (jd i think) value
mike
03-25-2002 00:17:24
hi was courious if anyone had a ruff idea what a 2 bottom 16 inch pull plow it is green and yellow has rope trip clutch lift on rubber tires i believe it to be jd all cutting edges appear to be in decent shape but tires are junk thanks .mike
Jerry S
03-26-2002 08:30:12
 Re: 2 bottom pull plow (jd i think) value in reply to mike, 03-25-2002 00:17:24
You should have some beam numbers stamped in the top of the beam as well as the maker of the plow that can help ID the plow. I saw one sell for 150 that sounds like this one a couple weeks ago.
Jerry S
03-26-2002 08:25:10
LH
03-25-2002 04:39:40
Most times the price for any plow is based roughly on $100 per bottom, but demand and collectibility often drive prices up or down.
