How much does a Ford 515 sickle mower weigh?
Mosey
03-27-2002 10:54:17
Sorry about another sickle bar mower question! I have a Ford 515 sickle bar mower with a 7' cutter bar. I'm guessing it weighs somewhat less than the average 5' bush hog (550lbs), but I'm not sure. The tractor picks it up easy. Has anybody ever weighed a sickle bar mower or know what the specifications claim this weighs?
David
03-27-2002 13:50:18
 Re: how much does a Ford 515 sickle mower weigh? in reply to Mosey, 03-27-2002 10:54:17
480 to 532 lbs
See attached or download the entire brochure at http://cedarranch.home.mindspring.com
Mosey
03-28-2002 05:48:19
 Re: Re: how much does a Ford 515 sickle mower weigh? in reply to David, 03-27-2002 13:50:18
Thanks! That sure is neat. It also answers some questions. The mid mount mower was the Ford 502, not 516, and uses the wobble shaft like the 515 (so it is odd that they didn't call it the 516). It also looks like I'm missing one small part, the bracket with a pin that the breakback arm attaches to (I have the arm and was wondering where it attached). I should be able to make one fairly easily. It’s also interesting to learn that it came in a 6’, 7’, and 8’ version. Do you measure the full length of the bar? I measured between the 2 farthest guards and it’s a couple inches short of 7’. Anyway, the 7’ mower must be in the middle of that weight range, which is 506lbs.
