Disk V. Runner planter: Which is better and WHY??
FM
03-29-2002 13:42:02
Which do you prefer and why? I was told that Runners have to have the ground better fitted down than disk. Is that true?
DP
03-31-2002 08:22:30
 Re: Disk V. Runner planter: Which is better and WHY?? in reply to FM, 03-29-2002 13:42:02
Along with what Tim said, the disc openers open a seed grove with less sidewall compaction and no compaction in the bottom, compared to a runner which just pushes a groove in the ground. The disc just give better growing conditions to the seed.
DP
03-31-2002 08:18:39
Tim(nj)
03-29-2002 15:20:29
Disk openers tolerate trash and clods better than runners, which is why you find disks on modern planters designed for minimum-tillage. Disks also work better in sticky soils like peat.
