Deere 510 baler
krig
04-03-2002 15:44:33
how much horse power is needed to run a 510 john deere round baler? Thanks in advance!
Bob Semrau
04-04-2002 07:37:35
 Re: deere 510 baler in reply to krig, 04-03-2002 15:44:33
I run mine with an Oliver 1600, 60 hp, with no problems on slightly rolling ground. My one piece of advice to you is to make sure your hay is dry before you start baling, or you'll be spending all of your time unwrapping hay from the feed rollers.
gy3020
04-03-2002 19:02:06
Horsepower should be about 70hp. I have pulled a 1560 Massey Baler with my 3020 John Deere and am now pulling my 530 Deere baler with my 3020. I am hoping to get a little bit larger tractor to pull it with this year. Ideally, in my opinion if you had around 90horses you would be doing fine. I have pulled the 530 with a 4430 I had but its really too much tractor for what you are doing. If you need a owners manual for a 510, I do have the manual for the early and later serial numbers. Just let me know!
Gary
jim hynden
10-09-2005 21:54:34
 Re: Re: deere 510 baler in reply to gy3020, 04-03-2002 19:02:06
Do you still have a manual for the 510 JD baler? If so, what do you want for it? Thanks, Jim
Jerry
02-25-2004 17:34:52
I pull mine with a 1355 moline. Has enough power to run half a dozen of those green things.
