290 John Deere Planter
jdman(MO)
04-07-2002 21:03:04
Anyone know how to change the seed drop? There seems to be nothing on the transmission to move. Russ
jdman(MO)
04-08-2002 21:03:06
 Re: 290 John Deere Planter in reply to jdman(MO), 04-07-2002 21:03:04
Thanks all, finally found the little lever which had been turned so as to be not real noticiable. Was also frozen but got it freed up. I guess those 42 years working on those things at 40,000 feet has taken the edge of my farm knowledge. Russ
David B
04-08-2002 17:47:00
The planting rate is controled by three different variables. Easy is 1-2-3 on the planter shaft, actually this slides the shaft back and forth in the gear box each position beig a differnt speed, a simple transmission. There should be two different sprockets to drive the gear box sprocket that is like a fast and slow to make the combination with the gear box shift lever six speeds in all. Then you have your choice of 16 cell or 24 cell plates which again vary the rate. It is all explained in a operators manual with population and hill distance charts. This can still be bought at your J D parts dealer
Ralph Ia
04-08-2002 14:37:50
There is a round shaft through the gear box. On one side, not sure which, there two holes in the shaft about 3/16" and maybe two inches apart. The shifter is held between the holes with cotter pins. This shaft moves left to right to change gears in the gear box. There are three choices.
Ralph Ia
04-08-2002 14:32:33
JMS/MN
04-07-2002 21:40:15
Look for a lever with the numbers 2,3, and 4 nearby. That is the number of kernels dropped per hill, at least on a 494. 290 might be similar.
jdman(MO)
04-07-2002 23:04:15
 Re: Re: 290 John Deere Planter in reply to JMS/MN, 04-07-2002 21:40:15
My old horse planter has a lever that says 2,3,4 but i can find nothing on the 290 but a lever to turn it off. Russ
JMS/MN
04-08-2002 08:55:00
 Re: Re: Re: 290 John Deere Planter in reply to jdman(MO), 04-07-2002 23:04:15
How about multiple sprockets with a flat drive chain, giving you different rates?
jdman(MO)
04-08-2002 13:46:52
 Re: Re: Re: Re: 290 John Deere Planter in reply to JMS/MN, 04-08-2002 08:55:00
Nope only one big sproket to one small one. But the plate has 24 holes maybe they do it with the plate. Russ
JMS/MN
04-08-2002 08:54:49
