Aerators for compacted soil??
rod
04-08-2002 15:38:31
Hi all I have a sand bed for sewage disposal it is mostly made up of sand to filter the drainage water now over the years the sand has been compacted quite a bit probably from using the ride on mower to mow the grass on it and I am wondering if there is an aerator or some other way to loosen the compacted sand up it is about 18 inches deep and 100 feet long by 20 feet wide ? Any ideas or advice as always welcome.
thanks rod
Dale (MI)
04-09-2002 06:48:10
 Re: Aerators for compacted soil?? in reply to rod, 04-08-2002 15:38:31
I've heard of a new technology that uses compressed air to restore drain fields. A friend found a contractor to use it on his failing field and he said it was effective and a lot less costly than a new field. I don't anything else about it. Do you have a good tank with baffles to keep solids out of your field?
