3 point boom pole
Brian
04-14-2002 20:51:06
I am looking to raise 28' 2x4 trusses aprox. 14 feet in the air, and was wondering if a modified boom pole behind my 3200 lb. VAC would do the trick? Or am I looking for trouble ? (Don't own a loader.) Thanks.
kb
04-15-2002 18:43:32
 Re: 3 point boom pole in reply to Brian, 04-14-2002 20:51:06
The process we've always used (it has worked for trusses between 24 2X4 to 28' 2X6 with addition 2' & 4' overhang (total length 34').
With the truss upside we raise one end and lay it up on the wall. With someone steadying that end we walk the other end up. Once it is supported by the walls we flip it up into place.
2X4 trusses aren't real heavy. My daughter (then 15) and I have had no problems picking up a 24' truss and moving them. They are much easier to carry upside-down, as you do not have to fight with gravity.
Brian
04-15-2002 16:02:40
Thanks for all the ideas, guys.
Hal/WA
04-15-2002 11:03:20
Most companies that deliver trusses have their trucks set up to lift the banded truss bundles on top of the erected and hopefully well braced walls. Unless the trusses are really long and heavy, it is possible to manhandle them into place from scaffolding, although it is hard work and slow.
Another option would be to build a well braced framework on your tractor to slightly lift the individual trusses from the stack on the top of the walls and move them to the location you need them with the tractor. I think this could be done with 2x6's and some bracing and using a come-along. Unless your 3 point is very controllable, I would leave it stationary and just use the come-along to do the lifting. Watch out for wind and have all of your truss locations clearly marked, so your help knows just where to put them. Installing the hurricaine clips before the trusses is a good way to make sure they get just where you want them. Be real careful and brace everything much better than you think you have to. It is a lousy feeling to see a pile of collapsed lumber where your building was supposed to be. Been there, done that. Good luck!
Chances R
04-15-2002 05:22:06
You are probally im trouble. Here is some pictures for you to see though.
George8NFL
04-15-2002 02:17:00
Use the tractor to pull the trusses up save your backs. Maybe even set up some kind of home made 3 point lift with pulley. Use 2x4 or 2x6 with pulley use tractor :) just my 2Cents
ShepFL
04-15-2002 06:34:58
 Re: Re: 3 point boom pole in reply to George8NFL, 04-15-2002 02:17:00
George is right on the money!!
That is how I lifted the metal cross beams for my shop. I just used a heavy rope across the top of the uprights, tied to 2 points on the beam and drove away from shop. After the beams were in place (height) I shut down the tractor, blocked the wheels and began MAN HANDLING them. 90% of my shop has been erected by myself, 10% has been some buddies helping to hang the sheet metal & roofing.
PS - George; how is that disking coming along?
JMS/MN
04-14-2002 22:15:16
If you had a loader with a hydraulic bucket, you could make a boom pole with enough swivel to raise those trusses. With your VAC, do you have a 3-point hitch to attach the boom? I doubt that an 8" stroke cylinder would pivot the boom enough to raise the trusses high enough. I'm sure the weight of the tractor would be enough if the mechanics of the linkage would work out. Personally, I'd just get a guy on each end, one in the middle, and push the first end up to the guy on top on one end, and pull the second end up with a rope. 28'foot truss is not all that heavy.
JMS/MN
04-14-2002 22:14:36
If you had aloader with a hydraulic bucket, you could make a boom pole with enough swivel to raise those trusses. With your VAC, do you have a 3-point hitch to attach the boom? I doubt that an 8" stroke cylinder would pivot the boom enough to raise the trusses high enough. I'm sure the weight of the tractor would be enough if the mechanics of the linkage would work out. Personally, I'd just get a guy on each end, one in the middle, and push the first end up to the guy on top on one end, and pull the second end up with a rope. 28'foot truss is not all that heavy.
