Harrow Question
Christian
04-18-2002 07:13:50
I'm in the market for my first harrow and looking for a 6 foot double disk to use on a 6 acre farm. It will be pulled by an 8N. My question is when I go to look at used harrows for sale what types of things should I look for or inpsect closely? Thanks in advance for your replies.
Christian
Jhill
04-18-2002 10:12:42
 Re: Harrow Question in reply to Christian, 04-18-2002 07:13:50
Look for worn worn bearings and the size and condition of the disc blades. Also look for rewelded frames.
Tim(nj)
04-18-2002 21:12:48
 Re: Re: Harrow Question in reply to Jhill, 04-18-2002 10:12:42
And look for bent axles, bent, broken or welded bearing mounts, bolt holes worn oblong. Also check to see if the axles turn. My neighbors bought a disk that had set so long outside, the bearings had frozen up.
