John deere plowboys i need help
36 A
04-21-2002 09:03:17
I have 2 john deere trailor plows. One steel other on rubber .they both tend to plow with the tail wheel in the air.what is the best place to start.
ET
04-22-2002 09:36:36
 Re: john deere plowboys i need help in reply to 36 A, 04-21-2002 09:03:17
Your hitch to the tractor is to high. It tends to roll the plow forward and pull the tail out of the ground.
ET
04-22-2002 10:59:12
 Re: Re: john deere plowboys i need help in reply to ET, 04-22-2002 09:36:36
You can raise the tractor drawbar or lower the hitch on the plow.
ET
04-22-2002 09:38:34
Bob Collins
04-22-2002 05:25:15
Probably the BEST place to start is with an operators manual, and get the plow adjusted for your tractor, without that, I'd say lower the hitch on the plow, the plates (John Deere calls them clevises)that bolt to the front of the beams will pivot up or down. Then the hitch support rod with the spring on it should be adjusted so when plowing there is about an inch of "slack" at the top of the spring. Are your points in good shape? try moving adjustments a little at a time until it works right for you. Good luck. Bob
