3 point backhoe -pto rpm?
Ron
04-21-2002 19:57:20
Picked up a used 3 pt backhoe-have been using it at low PTO rpm-don't see much difference in performance at higher rpm.Should I be running tractor pto at 540,or is lower ok? figure it's less wear and tear.Thanks,Ron
Burrhead
04-21-2002 21:58:35
 Re: 3 point backhoe -pto rpm? in reply to Ron, 04-21-2002 19:57:20
As long as you are happy with the responce time and it has enough power for what you are doing it's alright. The lower rpm will not hurt anything and will save wear and tear plus the fuel saved.
rhudson-Where have you been Burrhead?
04-22-2002 06:09:59
 Re: Re: 3 point backhoe -pto rpm? in reply to Burrhead, 04-21-2002 21:58:35
Where in the world have you been?
04-22-2002 06:04:56
