Ford Brush Hog Help
John, IN
04-26-2002 18:47:53
I have an older Ford brush hog. It leakes oil real bad and needs a new bottom seal. Does any body know what the seal # would be, or where I can find a parts list?
Ford, mod. 22-60 ser. 8520. Thank you.
JMS/MN
04-26-2002 23:04:50
 Re: Ford Brush Hog Help in reply to John, IN, 04-26-2002 18:47:53
If you know it's a Ford product and have the model and serial number, call a Ford dealer and he will help you get parts for it. If the seal is still intact, you may be able to see the number on it- if it's a generic number, any dealer should be able to cross-reference it with the info you already know. Ford was taken over by New Holland, who was taken over by Case-IH. If the original product was made by Ford, it shouldn't be that hard to figure out how to get parts. Some might think that's being sassy, but I can't believe how many people can't understand that the dealer is the first source to contact. When all the dealers are gone because of non-support, will the auto stores care if you can get parts?
John, IN
04-27-2002 05:52:47
 Re: Re: Ford Brush Hog Help in reply to JMS/MN, 04-26-2002 23:04:50
Yes I know that the dealer is the first place you should go for parts. But you see I can order bearing, seals and gears etc. through the place I work much cheaper, that is if they are not OEM. In this day and age you have to save every buck you can.
JWC
04-28-2002 12:57:44
 Re: Re: Re: Ford Brush Hog Help in reply to John, IN, 04-27-2002 05:52:47
When you say older that can go back along way. Is it Red or Blue? The gearbox and pedestal were the same for many years, but the earlier units had a smaller output shaft with 10 splines(?) and the later models had a larger shaft with 24 splines. You can go to a NAPA parts store or bearing shop and get a seal based on the diameter of the shaft and hole. New holland should be able to help you out. On parts like seals it is likely that there will be a difference of over 5 to 10 dollars over alternative sources. By the way Case-IH did not buy New Holland. Ford New Holland was bought by Fiat then Fiat bought Case-IH. Most of the tractor designs from FNH and CIH will soon be gone and replaced by Fiat designs.
Tom White
04-28-2002 16:01:46
 Re: Re: Re: Re: Ford Brush Hog Help in reply to JWC, 04-28-2002 12:57:44
If the tractors that Fiat produces are no better than their cars, that will be a real shame. Never did see a Fiat that held up at all.
