Howse dirt scoop measurement
Doug Stockman
05-07-2002 03:23:05
Greetings:
Can anyone tell me the distance from the dirt scoop pan bottom to the top link connection point? I am using a cobbled together three point hitch on a Farmall A that is a non-standard size. Before I get a dirt scoop I want to make sure it will fit the hitch. Thanks in advance.
Doug Stockman
Penfield, NY
Rubintropfen
05-07-2002 17:07:11
 Re: Howse dirt scoop measurement in reply to Doug Stockman, 05-07-2002 03:23:05
I get about 29" on mine. There is enough slop and an adjustment screw that you might be 1" or 2" more or less (whichever direction would be worse).
Doug Stockman
05-08-2002 03:06:36
 Re: Re: Howse dirt scoop measurement in reply to Rubintropfen, 05-07-2002 17:07:11
Thanks a bunch! That should work out great. I have a middlebuster and the top link is about 40 inches which is a bit too high. The dirt scoop should work out fine. Thanks again!.
Doug Stockman
Penfield, NY
