Bearings for IH Disk Harrow
MATT (BC)
05-13-2002 11:28:33
I'm restoring a IH Model 9A pull-type tandom disk harrow. The bearings are considerably sloopy on all axles. Parts manual shows the bearings to consist of a grooved upper&lower half bearing blocks with a inner steel/castiron bearing spool.
Are new bearing parts still available or do I need to look at other options to restore the tightness in the bearings???? Greatly appreciate a response. Matt
Ultradog MN
05-15-2002 05:07:23
 Re: Bearings for IH Disk Harrow in reply to MATT (BC), 05-13-2002 11:28:33
I bought an older 3 pt 4 gang disc this spring
and the wooden bearings were completely shot. Found a guy here locally that could order new cast iron bearing blocks for me complete with spools.
Paid about $150 for a set of 8 including shipping to my door.
I had to do some monkeying around - machining/welding to make them work for me but now I have a totally rebuilt disc
for not a heck of a lot of money.
If you want more info or his phone # email me.
Be glad to help.
MATT (BC)
05-14-2002 08:59:10
Thanks Guys: especially (Jerry D. in NC & ShepFC) advising to check out Agri-Supply's and also Hal advising to check Case IH. Case IH parts list indicate some original bearing parts available (not after market), but very expensive, eg. $80 just for one part of the bearing or $1920 to replace all 8 bearings. $100 is what I paid for the entire tandom disk.
I either use the disk as is or eventually figure out how to recondition the bearings.
Bill
05-15-2002 19:28:15
 Re: Re: Bearings for IH Disk Harrow in reply to MATT (BC), 05-14-2002 08:59:10
Check with B.W.MacNair & Son 717-543-5136 Tell them Bill Christopher from Okla sent ya. IF they got them they will send you good servicable bearings. Theyll need a part number maybe. Good luck
ShepFL
05-13-2002 11:56:33
As my 'net buddy Jerry of NC would tell me -
Check out>Link
For>Link my 10' IH transport disk I got bearings from Shoup's. They have a great catalog and FAST service. You can reach them at>Link
HTH>Link
Hal
05-13-2002 19:35:09
 Re: Re: Bearings for IH Disk Harrow in reply to ShepFL, 05-13-2002 11:56:33
I may be wrong, but I don't believe companies like Shoup handle the cast iron bearing parts. The top halves are usually unique, since they must bolt to the disk frame. They might be available from CaseIH but probably expensive.
Jerry D in NC
05-14-2002 05:08:37
 Re: Re: Re: Bearings for IH Disk Harrow in reply to Hal, 05-13-2002 19:35:09
If you go download the catalog .pdf pages 11-20 on Agri-Supply's web site, you will find on page 19 some of the bearing halves they have. Do not think this to be all that they have. Call the 800 number and you will get knowledgable people. If you can get the IH part number for cross reference that will help but call them. Maybe they help you find a substitute
ShepFL
05-13-2002 11:56:21
Check out>Link
HTH>Link
ShepFL
05-13-2002 11:53:49
Check out>Link
HTH>Link
Jerry D in NC
05-13-2002 13:20:41
 Re: Re: Bearings for IH Disk Harrow in reply to ShepFL, 05-13-2002 11:53:49
LOL I reckon I have become a "walking" advertisement. But it is sooooo much fun to go into the big boys toy store and get all kinds of things.....
ShepFL :)
05-14-2002 05:29:05
 Re: Re: Re: Bearings for IH Disk Harrow in reply to Jerry D in NC, 05-13-2002 13:20:41
No problem here!!
I have bought bearings from them in the past but never thought of umbrella and othe such things. I wish they would open one here in FL. Closest one is in Tifton, GA. I am going to run up there one day just to oogle and augle!
Take Care & thanks Jerry!!
ShepFL
ShepFL :)
05-14-2002 05:15:39
No problem here!!
ShepFL
