Farm Wagon Construction
TwinCreek
05-20-2002 07:05:14
I have begun building a home made farm/hay wagon out of a car straight front axle connected to a trailer back axle using a heavy wall pipe with bracing. My question is do you have to allow for flex using some kind of jount between the two axles or can the connection between the two be rigid. Thank you for your help.
TomH
05-20-2002 16:56:38
 Re: Farm Wagon Construction in reply to TwinCreek, 05-20-2002 07:05:14
Either build it to flex or build it strong enough to hold up a few tons of weight without breaking. Letting it twist is probably less prone to coming apart at a bad time imho.
paul
05-20-2002 09:30:18
I've seen 2-3 twin-rail ridgid wagon gears, and several thousand with a single pipe & joint on them. I suppose you can do either, but it looks like the flexable joint is a whole lot more popular... ;)
--->Paul
JMS/MN
05-20-2002 07:08:22
Check how a factory-made wagon is constructed. The reach will have a slotted connector ring on either the front wishbone or the rear one, allowing the axles to flex a considerable amount.
