Dansurd-Ford post hole digger
Chuck
05-23-2002 15:41:09
Need help on how to hook this thing up to my three point. There is a triangle that looks like the two lower arms go in it but if I hook the top link up to the top of the triangle I would have no control over the boom. What am I doing wrong?
Can post pictures if needed.
Thanks in advance
Chuck
Big Mike
05-25-2002 22:16:16
 Re: Dansurd-Ford post hole digger in reply to Chuck, 05-23-2002 15:41:09
Go to the Ford N series board here at YT tractor and post a message attention Ed Gooding and ask him to post a picture. He has posted them before but the link to the pic is no longer valid. Ed has one BIG of a collection of Ford related literature. The correct name for the digger is Danuser they were made by them for Ford..Big Mike
Big Mike
05-25-2002 22:12:35
paul
05-24-2002 05:38:18
Didn't see any pics of it on your web page. Plowing with a newer pickup - interesting thought. :)
Anyhow, most post hole diggers use part of the digger boom as the upper 3-point arm. Throw away the regular upper link you use with the disk & such - you don't use it! The boom of the post hole digger goes into the top link of the tractor, and somewhere on the boom there is a hole (or holes) that goes into the top of your A frame.
At least, that is how most work. Harder to explain that to do.
Sometimes aftermarket 3-points aren't quite standard, which can give different angles for something like a phd.
--->Paul
