Ford 501 mower
Kenneth S.
05-29-2002 21:13:44
Will a Ford 501 sickle fit a standard ASAE 3pt hitch on my Kubota? I can pick this one up fairly reasonable and think it might be easier than fooling with the JD #5 semi mount mower (no way to raise the cutterbar for turns). Any input on this mower would be appreciated.
Kenneth
Jerry D in NC
05-30-2002 02:44:32
 Re: Ford 501 mower in reply to Kenneth S., 05-29-2002 21:13:44
Kenneth,
The 501 will fit the 3pt but where you may have to make a modification is in the clamp on the left lift arm that locks the cutterbar lift mechanism to the arm. It will depend on the Kubota's lift arm shape. The 501 is adaptable to most machines. I have never tried the JD #5 but I got to think it is easier
chief 83
06-01-2002 07:12:10
 Re: Re: Ford 501 mower in reply to Jerry D in NC, 05-30-2002 02:44:32
I use a 501 on a JD870 now, and used the same mower on my old Kubota for years. It's a good mower and works well. Rather than change the mower (it won't just hook up the way it is) I purchased new lower 3-point arms. Most farm supply or implement dealers will have them. They need to be straight like the ones that are/were standard on an 8n Ford tractor. Cheaper and easier than modifications to the 501.
