Ford dearborn 2bot plow
gerry
05-30-2002 19:08:46
im looking for the cutter wheels for a ford dearborn 2bot plow. i need the wheels and the attachment the wheels are on. i dont need the rods thats bolted on the plow itself.
Scott
05-31-2002 17:21:46
 Re: ford dearborn 2bot plow in reply to gerry, 05-30-2002 19:08:46
Our old dealership has new ones available, do your shafts have a cotter pin hole in the bottom or a flat spot for a set screw to hold the fork?
gerry
05-31-2002 19:12:23
 Re: Re: ford dearborn 2bot plow in reply to Scott, 05-31-2002 17:21:46
dont know for sure ill look tomorrow. what is the name of your dealer and where is it located?
Ultradog MN
05-31-2002 04:35:15
The cutter wheels are called coulters.
I don't have any direct experience with this but I've read more than once that coulters are all pretty much the same. So you can start looking at more than just a coulter for a Dearborn.
HTH
UD
gerry
05-31-2002 15:19:11
 Re: Re: ford dearborn 2bot plow in reply to Ultradog MN, 05-31-2002 04:35:15
thanks ill start checking.
